22 fuel pump ?
13 years 8 months ago #59863 by CatinAZ
22 fuel pump ? was created by CatinAZ
Wondered if all 22s had a fuel pump. I know parts book shows one. Mine has a homemade plate covering where it should mount. Just has gravity feed to carb now and seems to run just fine.
'51 Massey 22, '51 Massey 44 w/ Massey trip loader, '62 Cub Cadet, '35 Cat 22
13 years 8 months ago #59869 by Steve A
Replied by Steve A on topic 22 fuel pump ?
I believe the newer ones did, not sure of the change date. The only time you will have a problem is going up a steap hill with low fuel in the tank
13 years 8 months ago #59870 by chugwater crawlers
Replied by chugwater crawlers on topic 22 fuel pump ?
I have a early series and it has a fuel pump. Rebuild kits are available.
A lot of twenty twos had the pump bypassed by the owner/operator when they failed, so you see a lot of them set up that way.
13 years 8 months ago #59871 by CatinAZ
Replied by CatinAZ on topic 22 fuel pump ?
That makes sense. thx
13 years 8 months ago #59884 by 22Randy
Replied by 22Randy on topic 22 fuel pump ?
I have to go uphill in some areas when I disc the weeds down so gravity feed didn't work for me. I installed a small electric pump and battery and that has worked out well. The battery will last about 5 hours before needing a charge and that is plenty for the small area that I do.
Cat 22
Serial# 2F237
13 years 8 months ago #59888 by 35CatTwentyTwo
Replied by 35CatTwentyTwo on topic 22 fuel pump ?
My Twenty Two is a '35 and it has a AC fuel pump. www.flickr.com/photos/17087539@N07/5753462298/in/photostream
13 years 8 months ago #59889 by 35CatTwentyTwo
My Cat runs fine but for future reference, who has the rebuild kits for these pumps?
Patrick
13 years 8 months ago #59908 by Willie
Replied by Willie on topic 22 fuel pump ?
Gravity works ok on flat ground and if you go up hills you have to keep the gastank full.All 22s had feulpumps the early were brass pumps and the dia. bolts on so all you need to do is cut one out of the proper material, the later used potmetal pump and it has same interal parts as a 50s-60s ford pump or carter pump on chevy. I think John Matta has the parts also. I was getting them from from the woodpecker guy in So Cal Clay Smith Racing Cams they use same dia in they high volume racing pumps. $12.
Time to create page: 0.182 seconds
