Sprockets broken
17 years 8 months ago #5713 by shocktower
Sprockets broken was created by shocktower
Ok how hard is it to repair sprockets ,or are there some to replace them with :confused: :confused:
17 years 8 months ago #5717 by Old Magnet
Replied by Old Magnet on topic Sprockets broken
Depends on what you mean by broken......if it's spokes that are cracked they can be welded up if within reason. If it's the sprocket ring, new rings can be fitted. If it's hubs ya need a whole replacement, good used would be fine or can be repaired as described. The preferred method of replacing rings is to pull the sprockets to do the work. It is also possible to cut the ring in half and weld it in place without splitting the track and pulling the sprocket but controlling alignment is more difficult with this method.
17 years 8 months ago #5729 by shocktower
Replied by shocktower on topic spokes
some of the spokes are cracked and welded ,I know today the welding on cast-iron is a little better
17 years 8 months ago #5734 by Old Magnet
The sprockets are high grade cast steel, welding is not a problem if done with reasonable care.
Time to create page: 0.131 seconds
