977 loader question
17 years 6 months ago #5706 by catd69u
977 loader question was created by catd69u
I have an 11K series 977K that is transferring transmission oil into the engine crankcase. I let it run about five minutes today, and it filled the engine so full that it started blowing oil out the crankcase breather. It done this in five minutes or less, as I had the correct amount of oil in the crankcase before I started it. What is the most likely cause of this? Any replies or suggestions will be greatly appreciated.
Barry Franklin
17 years 6 months ago #5708 by bob
Replied by bob on topic 977 loader question
Barry, you are most likely flooding the torque converter housing. Does there appear to be oil leaking out of the starter?
First you must determine if the scavenge pump is working. Drain converter housing and take off pump to inspect it. And also check and clean screen in 5 bolt housing at bottom where drain plug is.
It will most likely be alright but it is only meant to handle around 2 GPM of normal converter leakage.
Then if all is okay sofar determin the amount of oil the converter is leaking. I place an empty 5 gal pail in a larger bucket under the drain plug and start machine and stall conveter for one minute.(full throttle in 3rd gear holding the brakes)
You should only get a half pail but I think you will see a flood of oil coming out. If so first remove the trans pump from the front of converter housing and look for dammaged or missing seals on mounting face. (3 yellow rings) Also look in the two holes in pump for dammage inside the pump or a missing shaft bushing. If al is good this far the converter inlet relief valve in the large valve body mounted to converter could be stuck open but not very likely. If you find none of the above problems then you willl need to pull converter and inspect for problem. Coming apart, cracked housing or leaking seal ring.
Later Bob
17 years 6 months ago #5722 by catd69u
Replied by catd69u on topic 977 loader question
Bob, thanks for all the suggestions. I really appreciate it.I will check the things you mentioned and see what happens.
Barry
17 years 6 months ago #5725 by bob
Barry, have you had the machine long, any work been done to it lately?
Later Bob
17 years 6 months ago #5796 by catd69u
Bob, actually the machine belongs to a friend of mine, he bought it last year and hasn't got to use it yet. We just got it running the other day, so it had to have this problem when he bought it. When I get back to it in a few days, I will check it closer and let you know what I find.
Barry
17 years 6 months ago #5810 by bob
Barry, you guys have a Project on your hands. Since it's a newly purchaced machine, there is a good chance it was apart and put back together just to move well enough to load it.
In that case start by looking at anything that has been apart recently. Make sure the cooler lines are installed and not blocked.
Be careful it could turn into a money pit fast.
Later Bob
17 years 6 months ago #6056 by catd69u
Bob, to do the bucket under the drain plug test, do I need to do this while the scavenge pump is off the machine, or do I put it back on first? I'm a little confused.................................
Barry
17 years 6 months ago #6061 by bob
Barry, do it with the pump on and everything together. I would do this test first because you are looking for more oil going into the housing than the scavenge pump can take away. Cat converters usually leak about 2 GPM and the scavenge can handle all of that. If you get more than a 5 gal pail full in a minute then you have to find where it is coming from. Don't take out converter untill all checking is done, it could be coming from a few other places. The tractor might be a disaster someone put back together to sell or it might be something simple that has been over looked or put together wrong. Also look at cooler lines to see they are complete out of converter at valve with temp sender down to cooler at front and back to trans. They should be joined together with a cooler bypass valve. It's a piece of cast iron that both lines run through at the RH side of the engine. Look for any pieces of shim stock sticking out from lines where they mount. Someone might have blocked the lines off if there was a bad leak. This is going to be an interesting job for you guys.
Later Bob
17 years 6 months ago #6069 by catd69u
Thanks Bob, for all the help. I'll holler back at ya in a few days.
Barry
17 years 6 months ago #6159 by catd69u
Hey Bob I checked everthing you mentioned, scavenge pump is working, transmission pump looks good, cooler lines look like they haven't been messed with. The only thing I haven't checked is the inlet relief valve. I started it with the drain plug out, and it filled a five gallon bucket in about twenty seconds without even stalling the converter. Tomorrow I'm going to check the inlet relief valve, and if it looks ok then I guess I'll pull the torque converter................if you have any other suggestions I appreciate it.
Thanks, Barry
