D4 - 6U Timing the D315 Fuel Injection pump accessory drive to timing gears
13 years 7 months ago #57026 by pmduke
Our customer has purchased a partly dismantled D4 - 6U with the fuel injection pump and accessory drive removed from the engine and would like the procedure to time the accessory drive to the gear train.
He understands there is an offset tang on the front of the injection pump that engages with the rear of the accessory drive.
Just needs the procedure to time the accessory drive.
Is there timing marks on this gear?
Is the gear keyed to the shaft?
Thank You
Peter
13 years 7 months ago #57030 by Old Magnet
Does this engine have a balancer? (6U-9807-up)
For the non-balancer:
All gears have timing marks
All but the accessory drive idler have keyed shafts.
Start by:
1. Align the crankshaft gear mark with the large camshaft gear mark.
2. The idler drive gear is fixed to the cam gear.
3. The idler gear is a roving gear with an odd number of teeth.
4. Rotate the accessory drive gear until the idler will slip on and the timing marks (two) match.
13 years 7 months ago #57062 by pmduke
Replied by pmduke on topic Engine has a balancer
Thankyou you for the information so far it is very much appreciated.
The engine does have a balancer. From your comments the information you have supplied is for a Non Balancer engine arrangement. Is this correct?
Regards
Peter
13 years 7 months ago #57071 by Old Magnet
Yes, that is correct.
Here's the diagram for the balancer engine.
13 years 7 months ago #57251 by pmduke
Replied by pmduke on topic Thankyou
Thankyou very much for this information it is much appreciated.
Peter
1 month 1 day ago #259877 by bdkennedy70
1 month 1 day ago #259880 by Ray54
This is a 13 year old thread, a lot has changed. Back then their free photo scaring site that now charge for their services, and owner of diagrams may not what to pay. Also each member here only had so much space for pictures on the board. So old pictures were taken down to add new. Today many more pictures can be put up, but nobody goes back and cleans up situations like this. So if nobody comes forward with new diagrams start a new thread and ask again.
