- Thank you received: 0
Not much you can do with those "dog bone" links except split them down the middle, weld them up and re-machine. Can use drill bushings if you wish.
Bushings for the main quadrant shaft are still available from Cat or aftermarket source by dimension. The shaft seal can also be replaced. Big problem is that Cat used what I call "butter brinel" shafting that is way to soft for long life application and most likely will need replacement if worn. Bit of a job to replace but doable.
support@acmoc.org
- Chris R
- Jason N
