My wife got 2 new Cats, I showed her.
17 years 6 months ago #5345 by Steve A
She likes the soft furry ones, I like the old Iron kind. These pics are 2 of 3 PV 15,s that followed me home. Note the unusual rear pto drive, what would have it been used for.Both have good UC,good manifolds and loose engines, between the 3 I should have one good and most of a second. Just a few nights in the shop to put them togather, Right!
17 years 6 months ago #5346 by B4D2
Nice find Steve. You are getting like Ag-Mike with that old iron magnet in your head. Where do you find them? Hint-hint...do you need all them air intake screens? My 15 is lacking one.....:o PS, that funny PTO could be a rear crank for engine starting.
17 years 6 months ago #5351 by daron
Replied by daron on topic Pto
I'm thinking the pto was for a pulled implement using a driveline. The u-joints would be directly over hitch pin (helps with turns, etc.). Mower, bailer, combine, etc.
Daron
17 years 6 months ago #5353 by Pat in WI
Steve A,
My TEN has the same PTO. It was for a sickle mower. No splines, just a simple smooth shaft with a hole drilled through it for the mower drive gear or pitman drive (depending on brand of mower). The way that the mower was attached to the tractor required the drive to extend back much farther than a standard PTO. This was so the pitman arm would clear the track assembly.
Pat in WI
17 years 6 months ago #5377 by equipdriver
Looks like a good find. I wish I could get my wife to get more cats so I can get more cats. Are both those exhaust manifold heat boxes good ones? If so I might be interested if you have an extra one.
Karl
17 years 6 months ago #5379 by TractorDon
Nice find, yup, just a few evenings and you should have them up and running in short order:D Thanks for the pics. Don
17 years 6 months ago #5418 by Steve A
Thanks for the replys
Bruce, I hope to use one if the Aircleaner caps on my small 15, one of them is rough. I have to make a run to a junkyard I know of that has a big 15 with a good dash to make one of these nice, and a Seat box from steve weaver.
Karl
I will check, I might have a usable heat box.
I plan to make one complete machine and sell the second with a parts machine, I plan to have it running first.
Time to create page: 0.165 seconds
