- Thank you received: 820
Green Horn, thanks for the pics. That isn't the same magneto as mine though. I've seen the type you have. Your rotor doesn't have a gear on the rotor, correct? The magneto in my question has a rotor with a gear on it and the rotor meshes with another small drive gear. The small drive gear has two teeth with a taper, which I assume is a timing mark. My question is when you slip the rotor in place, does the contact on the rotor point towards those timing teeth on the drive gear. I figure it does, but was looking for documentation on it.
I finally remembered to write down the Caterpillar part number.
p/n- 4S6471. I'll take some pictures of this mystery mag.
support@acmoc.org
- Chris R
- Jason N
