Diesel Fuel in Crankcase of D47U
14 years 2 weeks ago #52222 by Mike Walsh
Now that you mention it, you may be able to remove the cap off the clutch housing and gain enough clearance. I never tried it as I needed to remove the entire clutch for other reasons.
The problem is that if you are removing the pump housing by hand, its weighs enough that you will not like having to reinstall it in the fuel tower if you have to remove additional stuff to gain clearance. Hopefully someone will have the answer before you pull it.
Sorry to hear about your mom. You are going to be very busy with her problem so the BB info will catch up long before you pull the pump.
14 years 2 weeks ago #52232 by bullcrk,6
Replied by bullcrk,6 on topic pump removal
remove the 4 nuts on pony clutch housing drain oil out of clutch and remove front cover this gives enough clearence to slide pump and govenor off as one unit its not as heavy as it looks much easier than seperating govenor and pump on tractor then you can put it on work bench for rest of repair install the same way back on tractor
i have done half a dozen 7Us this way its pretty straight forward and simple
10 years 11 months ago #96440 by Aussie John
Replied by Aussie John on topic D4 fuel leaks
Although this thread may be 3 years old, I found the information here, and on another similar thread very useful to do the same repair job on my D46U. I used a small chain hoist to take the weight of the pump & governor to save squashed fingers and by removing the cover plate on the pony motor clutch housing, there was plenty of room to swing it out onto the track. A 12'' 3/8 drive extension with a uni socket did the job on the back bolts. I am sure that Cat developed confined access on the way this pump is mounted. The pump shaft seal also replaced as it was hard and probably would have been damaged on re-assembly. About $16 for parts from Cat and 6 hrs of my time had it running again.
10 years 1 month ago #110477 by blwatson
Replied by blwatson on topic Fuel in Crankcase
I am a new member. I have a D4 7U serial #11867. I also have a problem with diesel fuel getting into the crankcase. I know this is an old post but should be very helpful. Can anyone tell me if replacing the two seals as suggested in this post solved the problem or if there could be additional areas to look at that my also contribute to the problem.
D47U
10 years 1 month ago #110482 by Old Magnet
Replacing the two seals, especially the one between the filter tower and pump is the usual solution to the problem.
In some cases where the fuel transfer pump seals fail and the drain line for the seal cavity is plugged fuel can also migrate to the sump.
10 years 1 month ago #110485 by blwatson
Thanks for the reply. Much appreciated.
D47U
10 years 1 month ago #110487 by drujinin
Replied by drujinin on topic blwatson
Took a little to find the link for you but you need to learn how to use the "SEARCH" function in the upper right of your screen.
www.acmoc.org/bb/showthread.php?9498-D4-...-part-numbers-needed
This Thread will be a good resource for you to read on the leaking seals and gaskets issues you are experiencing!
10 years 1 month ago #110495 by 933scotty
Replied by 933scotty on topic D4 fuel in oil
I think I may have same problem on my 5uD2. low fuel pressure changed filters no help The oil seem thin and stack slobbers very badly (black measles everywhere) also pump oil level was very high. It looks like the same setup as the d4 can it leak the same way and will it transfer fuel into the pump case as well?
10 years 1 month ago #110501 by drujinin
Yes, it is very common on both series of D2's also.
9 years 6 months ago #121622 by blwatson
Finally got to my cat after the snow melted and took the fuel injector pump housing and governor off to replace the O-ring seals. Took the housings off together and brought them back to town to work on them. Looking for advise before I start taking the two apart. I do not want to take any more of the governor apart than necessary. Looks like a linkage on the rack assembly. Not sure what else. Any help on which covers to remove would be appreciated. I did a search but was unable to find anything. Sorry if this has been covered numerous time before.
Bruce
D47U
Time to create page: 0.200 seconds
