Diesal Engine Rotation
17 years 7 months ago #5146 by railroadjoe220
What direcition does the deseal engine turn on a D47j? I want to mount a hydralic pump on the front of the engine.What rpm does the engine turn?How many gpm pump would I need to run a dozer blade?
Joe
17 years 7 months ago #5147 by SJ
Replied by SJ on topic Engine Rotation
All Cat engines take the rotation from the flywheel end which will be CCW but from the front as you are interested in it would be Clockwise.The full load RPMs on a 7J is 1400 RPMs & high idle would be 10% higher or about 1540 RPMs. As for the pump I don,t have specs here right off hand for the capacity output but I know OM on here would have it if anybody would. Just a little added info. Cat did on special application made the regular engines in the opposite rotation for some torque convertor rotation in some big drag lines that I have rebuilt the engines on.They could have been used in other applications but the drag lines & torque conv. rotation are the ones to come of mind.
17 years 7 months ago #5151 by D4Jim
Replied by D4Jim on topic Diesal Engine Rotation
RR Joe, OM can add a lot more to this but the original cat 44 hydraulics I believe were 29 or 40 gpm depending which cartridge was used. They were relative low pressure and operated about 1000 PSI.
My original hydraulic on the D47U was needing work so rather that fix it I took it off to work on it and installed another 18 gpm pump. It works fine for the dozer but it is slow when using the Cat 40 scraper I have. It is a 2500 psi pump. When I get time I want to redo the 44 system and put it back on.
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
17 years 7 months ago #5163 by 3512B
Replied by 3512B on topic engine rotation
TIGHTEN from the FRONT; LOSSEN from the REAR was how old Stocky told me to remember engine rotation.
Stocky worked for Jordan Milton in New Hampshire when I first went to work for them. Great old guy.
He passed away sometime ago, but I remember him fondly and use a lot of his advice daily.
Of course you have to watch engine rotation in marine application as some engines are opposite rotation.
Steve
