- Thank you received: 21
Check for rust build up at shoe - track link interface.
Richard--does the crack appear at the top of the shoe also? If it doesn't or is much smaller i would guess that it is a tension falure on the bottom of the shoe----Possibly from rocks between the edges of the shoes as they pass under the idler in a forward direction, or as they pass over the idler in a reverse direction.
Vers Vissa for the sprocket. ----
Dan
They Just Looky FUBAR
Worn Out , Thin, Stressed, Oxide Jacking on Rails etc. Time for new Rails and Pads, Likey Having a Punchture in a Rubber Track
Buggered Springs to Mind, How is the Rest of the Machine ???
CM
support@acmoc.org
- Chris R
- Jason N
