Cat D8 Combustion Chambers
17 years 7 months ago #4871
by MARTYN WILLIAMS
Hi there,my mate Sprocket has a 1944 D8R serial number 6718.The combustion chambers do not have any flats to insert a combustion tool.I think that the very early engines chambers were press fit and retained by the injector clamp.I am not 100% sure.Can anyone advise us.
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Thank you received: 815
17 years 7 months ago #4874
You are mostly correct. The early combustion chambers were pressed/driven in place. The two stud bolting arrangement was to retain the injector. Cat had the tooling to pull these chambers which consisted of a pulling shaft, nut and saddle which could be used manually or with a hydraulic puller.
I can't tell from the tooling picture but the pulling shaft must thread into something or maybe use a collet system.
17 years 7 months ago #4875
by SJ
Those old tall nozzles were held down in by two studs & nuts on each side of the chamber bore on the top outside of the head. Boy it seems those old chambers had threads on the top inside edge of them if I remember & there was a puller that you threaded the center puller bolt down into those chamber threads & the puller set down over the two studs that held the nozzles in & that way you pulled the chambers loose from down in the the head. It,s been so many years since I worked on one but I believe that,s the type you have & how you get them out.
17 years 7 months ago #4878
by MARTYN WILLIAMS
Many thanks,has anyone got cross section drawings? I assume that the chamber has an oring and a bottom sealing ring.Any part numbers for joints?
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
17 years 7 months ago #4879
by SJ
Don,t have a picture but they have a metal washer (gasket) at the bottom & an "O" ring seal at the top.
17 years 7 months ago #4880
This shows the cross section but cylinder heads after 2501 had water deflectors, otherwise the same.
17 years 7 months ago #4899
by MARTYN WILLIAMS
Many thanks to you all
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
17 years 7 months ago #4903
by Cel
Hi Martyn
I have a parts catalog for D8 - 8R1 to 8R9999; will trade it for a D8-2U parts catalog.
Best regards
Marcel
17 years 7 months ago #4927
by MARTYN WILLIAMS
Thanks Cel,will pass on info to my friend
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
