two tonne holt
two tonne holt
17 years 8 months ago #4068
by Stuss
we have dismantled 2 holt motors and found the gear on the front of crank shaft is badly worn; is this a common problem with these motors or is it my luck to have the only 2 with same problem.
Thank you received: 815
Thank you received: 344
17 years 8 months ago #4103
by edb
Hi Stuss,
if I recall correctly the 2TON -T35 timing gears were worn most on the crank gear by the thin oil pump drive gear, and, on the large idler gear by the water pump drive gear which also drives the fan drive gear and cam gear.
We closed our eyes and put them back together after champhering the gear tips and sides to stop any chance of the wear steps causing end thrust on its meshing gear. This is especially important if one uses thinner gaskets to assemble the unit-- Most especially the oil pump drive as it creates excessive thrust loads on the flanks of its drive gear resulting in oil pump seizure.
This occurs when the driven tooth butts up against the wear step in the drive gear.
Hope this helps and not confuses, Regards
17 years 8 months ago #4112
by Stuss
Thanks Eddie. I figured this is what I would have to do, just needed some clarification.
Thank you received: 115
17 years 8 months ago #4117
by naylorbros
Had a Cat 2-Ton open once that had the fan gear worn razor sharp on all of the teeth. The owner did not want to look any deeper so I do not know what the crank gears looked like.
Ken
two tonne holt
Time to create page: 0.143 seconds
