D2 4U Hyd. cyl.
17 years 8 months ago #3586 by Old Magnet
Replied by Old Magnet on topic D2 4U Hyd. cyl.
Look around on the castings. If they are Cat you should be able to find some numbers starting with 5F or 8F. The full numbers won't quite match the part numbers as the casting numbers are a little different but the 5F or 8F will tell whether they are Cat and whether they are early or late cylinders.
17 years 8 months ago #3587 by dpendzic
Replied by dpendzic on topic D2 4U Hyd. cyl.
those balderson pics help a lot--the cylinders do look similiar to mine but the rear anchor and front triangle support the cylinders pin onto are different, mine look like a cat 2S--but the blade has a balderson tag--Now i am really confused!!!
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
17 years 8 months ago #3588 by Old Magnet
D2 Cat 2S blade frame looks like this along with trunnion mounting.
Wouldn't be the first time someone grafted a different blade:confused:
Need to get some pictures.
17 years 8 months ago #3593 by dpendzic
oldmagnet--wow--that is exactly what i have--down to the 3 piece cutting edge:D
17 years 8 months ago #3658 by dpendzic
old magnet--here is a pic of what i have. looks like all is a cat 2s.
17 years 8 months ago #3663 by Old Magnet
Yes, it does look all Cat 2S.
ebay picture huh, did you buy it recently??
What was it that triggered the Balderson exercise??
What's that slab of iron on the side of the radiator??
Lots of questions huh!!!!
Oh ya, thanks for the pic.
17 years 8 months ago #3667 by dpendzic
bought it last fall on e-bay near beantown. The blade has a tag that says
balderson model B2S Serial # 57245
an industrial d311 engine was installed and that is the instrument panel they left there--i will change it though--hard to see while your operating the machine!! The oil pan has been changed to a D2 pan but i have to determine if the oil pump was changed also.
17 years 8 months ago #3670 by OzDozer
Replied by OzDozer on topic D2 4U Hyd. cyl.
Balderson built blades for Cats, that were so similar to Cat blades, it wasn't funny. They even made up their spec sheets to look like Cat spec sheets. I think you'll find that the hyd cylinders are Cat, though.
cgi.ebay.com/BALDERSON-ANGLING-BLADES-BR...tem#ebayphotohosting
