D2 running in circles
17 years 10 months ago #2957 by pvglasguy
I've been looking for a D2 with blade and found one advertised not to far from home. But he says he loaned it to a friend and when he got it back steering one side not working. My question would be what might be wrong,what to look for and how to fix
17 years 10 months ago #2960 by ccjersey
Replied by ccjersey on topic D2 running in circles
Could be an adjustment or the steering clutches could be stuck or worn out, two different symptoms.
If it is not pulling on one side, (you pull the opposite side steering clutch lever, and the tractor stops), that could be needing to adjust the free travel back to 3" on the steering clutch lever, linkage could be stuck, but probably the steering clutch pack is worn out or something broke in that side/final drive. You would hear/feel clunking maybe and find metal in the drain plug of the final drive if it's the gears.
If the clutch on one side will not disengage to allow you to turn to that side, the clutch lever adjustment could be too loose, linkage could be broken, throwout bearing could be gone or most likely the clutch pack is frozen up. These stuck clutches can sometimes be adjusted up tight (no free travel) and the tractor butted up against something big and heavy with the clutch held back to attempt to slip the clutch pack.
Which is it?
17 years 10 months ago #2961 by SJ
Replied by SJ on topic D2 Post
CC this brings back a joke I heard years ago & it goes "Blessed Are They Who Go Around In Circle For They Shall Be Known As Big Wheels".Well if he tries your suggestion he should possibly pin down the problem with the steering.
17 years 10 months ago #2998 by pvglasguy
Replied by pvglasguy on topic D2 running in circles
Thanks CC, I'll be a looky Lou next week,right now I need to figure out whats going on with the RD4 something going on with govenener diesel is "searching"
17 years 10 months ago #3014 by Delta Dirt
Replied by Delta Dirt on topic D2 running in circles
SJ----"Blessed Are They Who Go Around In Circle For They Shall Be Known As Big Wheels".
I've been running in circles for so long----that now ever time I come by a dog, the dog hikes his leg and tries to "hose off" my leg (and I don't have a wooden leg). Must be some truth to your statement.:D
I did have an older friend (WWII vet) with a wooden leg----Walter always claimed he had to be careful around dogs.:rolleyes:
Excuse me for posting off topic material within a legitimate post----but dogs were mentioned here and dogs chase Cats----so we are now back on topic.;)
Delta Dirt
Delta Dirt
Avon, Ms 38723
D2 5U and other scrap iron
