627 Tachometer
627 Tachometer
17 years 7 months ago #2837
by Neil D
I have a 627 push-pull s/n 68M00471, the tachometer is busted,can anybody tell me if a tacho from a 623F will work( part no 225-0283) or suggest a solution.
17 years 7 months ago #2839
by SJ
First check if it fits in the dash ok & then if the other end thread is the same to attach to the drive. Also check & see if the drive is the same RPMs on both by turning the main engine over one turn & see if the cable drives are say 1/2 RPMs or whatever they,re geared at.It seems older engine drives were half engine speed if I recall but not sure anymore on one of them. Also make sure the drive cable is long enough unless the original can be used.
17 years 7 months ago #2903
by alan627b
A 627 with a working tachometer? You must really spoil your operators, Ive been running the B models for 14 years and have only seen 1 that worked!
We need proof they exist!LOL!
alan627b
17 years 7 months ago #2904
by Neil D
Hi Alan
I bought this machine last year and am looking for a second one for some work that we have coming up. We are getting the machine ready for this work and as I will be driving it I wanted it in as good a condition as possible.
Somehow I knew someone like you would come on the board with those remarks!!!!!! Do you know why the tachos never work? Because the price of a new one is £568 which I suppose is $1000, what a rip-off.
Contact me at <a href="This email address is being protected from spambots. You need JavaScript enabled to view it." target="_blank">This email address is being protected from spambots. You need JavaScript enabled to view it.
17 years 7 months ago #2925
by alan627b
Yikes! Neil, that has to hurt! I wonder if a guy could get an elctronic tach sender, and just put a 5 inch Autometer monster tach in the hole? It would look cool......where does a guy find a 627 in Ireland? Plenty of them here, but I'll bet it's not easy where you are.
Good luck with your purchase, hope to see some pics of it before too long!
alan627b
by the way, in case you might wonder why some folks call me "Flip", check out what some may call my best work, but don't try this at home!
link
www.heavyequipmentforums.com/Forum/showthread.php?t=259
You might have to register to view it, but it's a good forum. My work is back a ways....
627 Tachometer
Time to create page: 0.389 seconds
