- Thank you received: 0
Hello Radcam......and welcome.
Not likely it is either one of those causes. If the transfer pump seals are leaking you will have fuel leaking from the drain line that drains the cavity between the transfer pump seals.
The most likely cause is a dried out seal between the fuel filter tower and the injection pump housing which will allow fuel to leak back into the sump.
In the picture it is the seal shown in the upper RH corner.
Part number is 6B4967
There is another same seal at the opposite end of the injection pump housing that should be replaced at the same time.
cat@acmoc.org
- Chris R
- Jason N
