Pony clutch wet/dry?
15 years 5 months ago #23645
by greyhead
Hi guys; Ive been reading the threads about pony clutchs having oil in them
When I rebuilt the main ,I went around a changed oils in everything.
(fuel pump ,steering booster ,trany ,final drives...) But when I pulled the cover on the clutch it was dry showing no sign of oil. But now I wounder:rolleyes:
D7-3T #38151 hope I hav'nt made a O-#%!@
thanks Brad
CAT 977K-11K, JD450-B ,JD690-B, IH TD-9 ,CASE 450-B JD750-E JD850-B
CAT D7-3T, KOMATSU P-68-8 LGP, CLARK 55A LOADER
CLARK MICHAGAN 85-C LOADER, CAT V60 FORKLIFT
And some old AC tractors
Thank you received: 99
15 years 5 months ago #23649
by greyhead
Thank for the reply, A bit worryed
But why the change anyone know?
15 years 5 months ago #23650
by SJ
I have an older D8800 power unit operators manual and shows two oil cups to fill at given hours of running but I just can,t remember on the later D8800 in the D7 3T SN so check and see if there is a couple cups to fill.
Thank you received: 737
15 years 5 months ago #23653
The dry clutches on the early side winder ponies use a clutch that looks like a miniature dry main clutch, single disc. collar, etc.
The pancake ponies use a multi-disc clutch which is much more compact in size.
Time to create page: 0.143 seconds
