D2 staring motor
D2 staring motor
15 years 5 months ago #23486
by Tugger
Hello
i went to start the D2 today,its been sitting for a month in the shop.it ran and started fine the last time.now it apears to have no spark.it always flashed up on the second or third pull before.now after sitting ,no go.what can go wrong with a magneto under these circumstances,its dry in the shop.i checked the kill switch and even disconected the wire from the kill switch.any suggestions.ive never had much to with magnetos
regards
Dave
15 years 5 months ago #23487
by Tractorboy1
Unfortunately sometimes it doesn't take much for these magneto's to quit.
The magneto problably has some build up on the points.
If you can take the cap off and gently sand the points, this may solve the problem.
I have gone as far as taking the mageto out and bench testing it to make sure it works.
It sounds like the points arte not working.
Good luck,
Tractorboy1
Thank you received: 737
15 years 5 months ago #23498
Sometimes it takes some pretty aggressive filing of the points to get conductivity.
Best way to check is to lift the mag wire off the ground (upper LH corner) and check for conductivity across closed points....then you know for sure.....common problem:)
15 years 5 months ago #23509
by Soapy
I experienced a similar situation a few years back with a Wico mag on a A John Deere that sat all winter. Pulled out my capacitor checker, and found a dead short. Installed a new one, and it hasn't failed to fire since.
Thank you received: 19
15 years 5 months ago #23510
by D6 Pete
Are you getting fuel into it ?, ive had more trouble there !! , mostly at tank outlet into the glass bowl etc... Regards, pete
15 years 5 months ago #23518
by Tugger
Yes im getting too much fuel actually,seems like a stuck float maybe
always have had to be careful with the choke and the throttle when starting.i always shut the fuel off to to stop the starting motor
15 years 5 months ago #23520
by Vinny
Tugger,
All of the above. Moisture will corrode the points, the float will stick, gotta love these critters. LOL.
Chris
D2 staring motor
Time to create page: 0.158 seconds
