New to the forum
New to the forum
15 years 5 months ago #23387
by Meskie
Found this site looking for some help for my d7 17A. It is currently stuck in forward and first Gear. Trying to clear some brush on a fenceline. Any help would be great.
Thank you received: 737
15 years 5 months ago #23392
Most likely a problem with the lock out system...If the other gears were working ok you probably have a stuck interlock plunger. 1st and fwd/rev. are on the bottom counter shaft and 1st is the bottom shift rail. You can check the plunger by pulling the small cover and plate and try prying the shift rails and forks back to the proper position. If it doesn't respond you will have to pull the large cover/assembly and sort out what's wrong.
15 years 5 months ago #23395
by Willie
Try looking at the clevis pin on the lock asbly on the clutch lever, The pin often falls out and you either get locked in gear or outta gear look under the deck below the main gearshift lever will be little rod that goes to cluch lever end to a little arm with a pin. its easiest to check first and habit of coming out.
15 years 5 months ago #23397
Yes, good point...make sure lock out linkage is connected....just assumed you already checked that:)
15 years 5 months ago #23499
by Meskie
Thanks for the tips havent had time to look at it been busy and cat is 25 miles away from home. it was jumping out of first gear and i put a tarp strap on to hold it in worked fine for a long time until i couldn't shift into reverse or neutral and the trans. shift lever is is also stuck in 1st gear now. hard to clean up trees with no reverse. thanks again for the help.
15 years 5 months ago #23502
If it's been a gradual change as you describe.....may be nothing more than an adjustment of the interlock cam required.
New to the forum
Time to create page: 0.146 seconds
