1942 D47J Cylinder packing? 5" piston
4 days 9 hours ago #261712 by CamaroMan
Hi all - despite snugging chevron seals my blade still drops slowly, pulled the piston on one side and the two opposing rubber seals seem a little hard. luckily bore and shaft seem fine except fpr some dirt in the bottom which i cleaned out-
Someone kindly posted this part number 5F3348 but i found a site that shows it as a 7" seal- my piston measures 5"- my cylinder number is 3f9359.
4 days 9 hours ago #261713 by CamaroMan
I wonder if these SKF single direction seals would hold up -
www.skf.com/us/products/industrial-seals...als/unp-profile-data
1 day 5 hours ago #261733 by trainzkid88
the seals are available as we had them replaced when we did up our rams on our 6u
1 day 5 hours ago #261734 by trainzkid88
try a hydraulics shop. there is probably a generic seal that will fit. i cant remember if we used genuine seals or not.
my parts book for the type 44 hydraulic unit lists for a 5 1/4 bore x 24 stroke 5f3383 as the piston packing and 4f8420 as the vee packing 1b936(1st and 2nd type ram) and 1k6982 for the third style of ram i seem to remember we got genuine parts.
1 day 5 hours ago #261735 by trainzkid88
if you clean up that part number on the casting someone may have the parts diagram you need or perhaps you local dealer can find it from that part number
23 hours 16 minutes ago #261738 by Moparnut88
look up hercules sealing products. it is who is use for my hydraulic cylinder kits.
21 hours 2 minutes ago #261739 by CamaroMan
ive been all over the net and even went to a local shop who were useless. spent 3 hours on calls all over the palce. Cats website has no seal with those specs and some of their seals are missing data so it might be there.
My cylinder bore is 4.750 and piston seal OD is 3.750- 5.16 width. emailed a bunch of places. I dont just come here crying at the first go- ive literally been at it for 3 days.
Ill try hercules thanks- my piston is a 3 piece worst case i can machine new end plates to accommodate cat seal. They do list one for a 4.750 bore at least-
and fwiw my seals are called buffer seals and used as the primary seal in the piston - very confusing but yes thats how it is.
18 hours 9 minutes ago #261740 by side-seat
On a D4 I was working on a couple years ago I had to machine the gland housings to fit a set of different chevrons and the wiper seal. One of them was so corroded from coal dust from years of neglect in a coal mine, I had to set it up in the mill and keep boring it out till I got the sleeve that pushed on the chevrons out. Don't know exactly what seals we used because my son got them from his work that has a hydraulic division that rebuilds all sizes of cylinders for the mines and steel mills. The piston seals if I remember correctly were good to re-use and are probably a later style because it has 3 rings.
I can check and see if he remembers any numbers we used. I might be able to post some pictures once I figure out how to load them from my phone.
16 hours 20 minutes ago #261741 by wimmera farmer
I have been told Hercules manufactured seals for Caterpillar for many years and possibly stil ldo. Pretty safe bet Cat never ever made their own. Worst case it would not be hard to make a new piston once you have the correct dimensions for the seal groves. best of luck WF
15 hours 56 minutes ago #261742 by Deas Plant.
Hi, CamaroMan.
When chasing parts for older Cats, it is often necessary for the parts people to go to a separate section of their parts catalogue called "Classic Caterpillar". Try asking your local dealer to check that out on their parts computer.
Time to create page: 0.344 seconds
