RUST - stronger than SUPER GLUE! Fills gaps as well as filler rod too.
Dry Clutch -- Assuming it may be a double disc clutch?
I would use a whole lot of thought about trying to break it loose by RELEASING STEERING CLUTCHES under POWER!
DAMAGE FROM such actions can result in Catastrophic failures - just remember, all components are only as strong as the weakest part.
I have first hand experience with "Frozen-rusted-stuck" slip clutches designed to protect drive lines and drive trains.
Category 4 shaft on John Deere HX 15 mower looked like a rifle barrel, of course the U-joint went to parts somewhere close to orbit. All due to a clutch pack that was rusted to the drive plates! I don't think the governor even had a chance to react to the instant loading on the tractor.
Needless to say - I am not a fan of "slip clutches", I would far rather work with flanges and shear bolts, sure saves a lot of mess and expense.
In the event a slip clutch assembly does slip, it often results in total loss of the very thin linings so back to replacement again.
( When I was in the Snow Removal work - many of the snow blowers were powered with 12V71 Detroits, through a torque converter, to the drive line. 2 - 1/4" scored grade 5 bolts in the primary shear flange delivered the power to the blower head. I do not recall ever losing a drive line. The reels or augers usually had 3/8 or 5/16 bolts in the shear flange, set 180 degrees apart, the fans, also shear protected, had 2 - 3/8" bolts, same bolt at teh auger-reel. Sure saved lots of drive lines and gear boxes!)
Years ago, my father "broke" the stuck clutch plate in our Ford NAA by using a flattened file tang, carefully drove it between the flywheel and clutch disc with the Clutch Pedal in dis-engaged position. One must be gentle and try in several locations working slowly.
Do not get the "prying" instrument between the lining and the clutch disc itself, they are typically riveted and you will either pop the rivets or break the lining.
Make sure the clutch linkage is in the released positions - something has to be able to move as you "wedge" the disc from the plate or flywheel.
I should also remind everyone - RUST or corrosion fills gaps and space. If there is no place for movement, driving a wedge in between the clutch disc and the steel pressure/plate flywheel will only result in damage. Careful Examination is required before one damages components.
We have all seen Steering Clutch packs that have rusted so badly, the springs had to be cut off with a torch and the pack was total garbage.
Proceed with care, wear eye protection!
CTS
