3J D2 clutch help
3J D2 clutch help
1 month 2 days ago #261173
by JbinkD2
Hi all I am new to these machine I just got this D2 and the main clutch is stuck the clutch lever travels back and forth but the clutch does not move at all. Any suggestions on how to free this up? Do I have to split the tractor or can I work through the access hole? Thank you.
ChrisE
Thank you received: 52
1 month 2 days ago #261174
by CrawlerAddict
Judging by the amount of rust and corrosion in the picture I would say the pressure plate is probably frozen on the shaft. There are external teeth cut on the shaft and internal teeth cut on the plate that facilitate movement of engagement and disengagement of the clutch. Most likely will have to pull the engine but I would try a 50/50 mixture of acetone/transmission fluid to spray on everything and soak it. Then maybe a little heat and some light tapping of a hammer may free it up.
Good luck!
CrawlerAddict
Thank you received: 38
1 month 2 days ago - 1 month 2 days ago #261176
by clayton
Also your interlock needs to be bolted back up in the two bolt holes which keeps the transmission from coming out of gear/going in gear until you engage your clutch you will want to fix that.
Last edit: 1 month 2 days ago by
clayton.
3J D2 clutch help
Time to create page: 0.137 seconds
