D4c240 hydraulic pupmp shaft seal
1 month 2 weeks ago #260899 by wimmera farmer
Trying to get a few more running for 100yrs of Caterpillar next year. D4C 240 Australian assembly same as 40A I believe. Hydraulic oil is getting into engine sump. Only place I can think of would be the drive shaft on the hydraulic pump. I have parts book for the tractor but it does  not show the hydraulic pump can someone please post a parts diagram or part number. thanks for looking WF
1 month 6 days ago #261095 by wimmera farmer
Refreshing, surely someone knows a bit about these. happy New Year
1 month 5 days ago #261116 by juiceman
If you can look at the tag on your tank, I might be able to narrow it down to GPM. Here is what I have for 39A and 40A machines. See if you can determine the serial number for your 141 or 143 unit. JM
The following user(s) said Thank You: Busso20
1 month 5 days ago #261129 by wimmera farmer
Thanks Juiceman. No tag on the tank unless it is behind the dash panel, surley not. Only clue i have is pump has cast on the end Vickers Vane and some patent numbers I can't decipher. Both the parts diagram you kindly posted show the same part number for the seal 4J980 so that may be a starting point. thanks WF
1 month 5 days ago #261130 by ChrisE
Hi WF.
I suspect that the seal on the shaft would be a double lip seal that should be available at a bearing shop in Horsham. If the kidney plate seals are gone they might be able to match them at a hydraulic shop. It will be a gear type pump looking at the shape of it so should be
easy to fix. Most gear type pumps i have had apart you can get seals for locally. Good luck.
1 month 4 days ago #261149 by trainzkid88
sperry-vickers is now part of eaton fluid power. so any decent hydrualics joint should be able to source parts for it. and yes that seal is probably a generic double or triple lip seal.
1 month 3 days ago #261159 by wimmera farmer
Will get ito it next week when the shops are over their xmas pudding.
Time to create page: 0.145 seconds
