RD4 engine oil leak
1 week 5 days ago #260197 by wildwylee
I picked up this 1937 RD4 and she runs and operates fine other than a steady small stream of oil leaking out of the rear engine seal. My question is what kind of seal (if any) is on the crankshaft it’s self. I’ve read that some older machines just have threads cut into the crank to keep pushing oil back in, would an RD4 be like that or will it have a rope seal? I have the shop manual and parts book for the machine but can’t find any details on what I want to know. It only shows “packing” that looks like it seals the rear main bearing cap to the block, if this packing is bad would it let a steady stream of engine oil run out?  If anyone has any information or pictures of the rear seal of an engine that would be great! Also if anyone knows a part# for an oil filter off the top of their head that would be great!  Thanks, wylee
1 week 5 days ago #260200 by side-seat
Replied by side-seat on topic RD4 engine oil leak
Search this forum. There's been topics on this from others.
I've never had one of these engines apart but on most of the older Cat engines there's no seal only a reverse Buttress thread that pushed the oil back into a drain hole that goes back into the crankcase. You may want to check and see if the breather on the right side of the engine is clean. Could be too much crankcase pressure.
1 week 5 days ago #260203 by wildwylee
Replied by wildwylee on topic RD4 engine oil leak
Thanks, I’m new to the forum and did find the search bar and the other posts. I’ve never tore apart any old diesel engines before, I mostly have gas v8 experience. This is my first dozer project. I checked the breather and it’s clean. If the drain hole is plugged would it cause a substantial oil leak? I can only run the machine for an hour or so before I need to add more oil. Is it possible to leak that much if the packing between the main cap and the block is shot?
1 week 4 days ago #260216 by 8C 361
Replied by 8C 361 on topic RD4 engine oil leak
Perhaps the main bearings are worn beyond spec and allowing too much oil for the reverse thread too handle.
1 week 3 days ago #260224 by neil
Replied by neil on topic RD4 engine oil leak
On my 5U, the problem was that the bearing had corroded some because the tractor had ben sitting and the groove had filled up with gunk. I had to fit new bearings due to the crank needing to be turned down and I had the guy also clean out the groove. No problems with it now - I don't recall cleaning the breather but may have
Time to create page: 0.238 seconds
