'New' D2, unknown starter motor
3 weeks 4 days ago #259979 by neil
12v is fine. My brother's truck had a 903ci engine with a 12v starter - never had any problem cranking it, and it's 3x the size of a D2 engine. All you need to do is make sure that the main cables between the battery and the starter motor are sized correctly for the current and all connections are clean and bright
The following user(s) said Thank You: RHX
3 weeks 3 days ago #260007 by trainzkid88
use 2b&s size cable. any smaller is useless as it wont carry enough power. you can often buy pre terminated cables in this size from the local auto parts joint or auto-electrical shop. all connection points need to be clean to bare metal. a light smear of conductive grease helps with moisture proofing.
wire your batteries in parallel to get extra starting power. and use relays and starter soleniods to control the starter.
3 weeks 2 days ago - 3 weeks 2 days ago #260019 by RHX
Replied by RHX on topic 'New' D2, unknown starter motor
@trainzkid88 @neil Used 2/0 except for the 1/0 piece between bat + and the main power switch.
Overview/wrapup
Continued discussion here with other questions/issues
www.acmoc.org/bb/discussion-d72/32503-new-d2-cont
Last edit: 3 weeks 2 days ago by RHX. Reason: add video
3 weeks 2 days ago #260022 by neil
Perfect - I used 00 for 6v so for 12v, that's plenty
3 weeks 1 day ago #260035 by Claremontcat
Here's some pics of what I have - 1954 D2-5U #13247
3 weeks 1 day ago #260036 by Claremontcat
Starter switch - turn left for glow plugs, right to start.
3 weeks 1 day ago #260037 by Claremontcat
Don't know why there is 2 solenoids - ain't broke so never tried to fix it
3 weeks 1 day ago #260039 by daron
Don't know why there is 2 solenoids - ain't broke so never tOneeried to fix it
One for starter, one for glpowplugs.
Daron
3 weeks 1 day ago #260047 by trainzkid88
someone showed you the proper way wire a battery bank, you have the supply wires at opposite ends of the battery bank that way it acts like one big battery and you dont kill the one battery.
Time to create page: 0.196 seconds
