Rusty D 2
3 months 6 days ago #259516 by d4angelo
Rusty D 2 was created by d4angelo
Hi guys, I am helping a buddy work on his D2. It was left outside in the rain last year and every compartment is seized up. I want to pour something in both steering clutch compartments to free them up. What works? I have heard about Kerosene but it is hard to find around here. Some options might be Diesel fuel or vinegar. Any thoughts?
3 months 5 days ago #259518 by clayton
Replied by clayton on topic Rusty D 2
Put diesel fuel in the steering clutch compartments and let it sit for a few days then operate it and see if they freed up may have to work it hard for a bit to get them freed up.
3 months 5 days ago #259520 by dpendzic
Replied by dpendzic on topic Rusty D 2
I used diesel fuel in my steering clutches and it freed up--chained it to a tree and by alternating forward and reverse they became loose
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
3 months 5 days ago #259523 by juiceman
Replied by juiceman on topic Rusty D 2
Yes Ang. Start it up and work it back and forth after it had a chance to soak. Pictures please, or it didn't happen as some would say...JM
3 months 5 days ago #259525 by d4angelo
Replied by d4angelo on topic Rusty D 2
Thanks for the help guys. Pictures to follow JM
3 months 3 days ago #259554 by d4angelo
More on the rusty D2. Engine was separated from machine and I was able to release the main clutch lever. I removed the clutch and found both sides of the pressure plate badly rusted and pitted. I was able to use a flap disc to remove the surface rust. I used a small flat blade screwdriver to clean the lines across the fiber disc. My next hurdle is to find out why the pony piƱon lever will not move. It is frozen in place and will not budge. Any thoughts? I really don't want to remove the pony from the diesel main if I don't have to. Suggestions please!
3 months 3 days ago #259555 by gemdozer
Replied by gemdozer on topic Rusty D 2
The pine on bar could be ben or linkage is missing lubrification and am not sure if he has a greace fitting in bottom
3 months 3 days ago #259556 by neil
Replied by neil on topic Rusty D 2
Hi Angelo!, does the pinion engage if you push on the end by hand, ignoring the lever and the arm that engages it? If it does, then I'd say the lever shaft, or the arm in the slide is seized. What you could do is manually engage the pinion, apply some mild heat and penetrating oil, then lightly tap on the lever and/or arm and see if you can initiate some movement. If you can, then just work it/them back and forth applying more oil and it should loosen up.
3 months 2 days ago #259562 by d4angelo
Thanks for the help guys. Neil, I don't really want to beat on the end of the pinon shaft because the brake is on the end of that. Keep in mind, nothing moves! Removing the pony might be easier with the main diesel removed from the chassis.
3 months 1 day ago #259570 by neil
Oh I see, not even any movement? I think you're right then Angelo, remove and disassemble sounds like the right approach
Time to create page: 0.193 seconds
