D4 clutch collar washer?
1 month 3 weeks ago #259493 by Haus
My clutch collar (the internal part) had a washer to take up some of the wear in the bronze outer collar. Anyone seen this before?
Now I'm putting a new bronze outer collar on, is it worth trying to take up some of the slack with a new slimmer washer, or should I just leave it alone. There is about ~3mm (1/8") slack between the old internal collar and the new bronze outer collar.
Paul.
1 month 3 weeks ago #259497 by neil
Replied by neil on topic D4 clutch collar washer?
Hi Paul, that 3mm seems about the same as I had on my 5U when I fitted a new bronze collar from General Gear. Their advice was to ensure it was always well-oiled e.g. make sure the oiling cup and tube is clean and operational, and oil it before every start up. If you were to work for more than four hours then oil it again
The following user(s) said Thank You: Busso20
1 month 3 weeks ago #259509 by Haus
Replied by Haus on topic D4 clutch collar washer?
Thanks Neil - I appreciate the advice. I'll put it back together with out the washer.
Paul.
Time to create page: 0.131 seconds
