No. 33 grader - oil & seals
Thank you received: 49
15 years 6 months ago #22573
by Delta KJ
I have begun restoring my No. 33 hand control pull grader, and I have an original parts book for the grader. My first task was to remove the blade table and disassemble the gear box. I noticed that there were no seals or gaskets in the gear box. The parts book doesn't make any reference to any seals or gaskets either. It is my understanding that these gear boxes hold some form of lubricant; there are plugs in the gear boxes where oil can be added.
What lubricant should be used in the gear boxes?
How are the gear boxes sealed?
Thank you.
15 years 6 months ago #22575
by Willie
The opp book says use transmission fluid in some and simi-fluid lub in others, Im guessing the sim-fluid is what we use for the rollers because it talks about useing the volume pump. If you send me your EMail add. I'll try and coppy the lub chat and send to you. <a href="This email address is being protected from spambots. You need JavaScript enabled to view it." target="_blank">This email address is being protected from spambots. You need JavaScript enabled to view it.
Time to create page: 0.115 seconds
