Cat 22 rusted fuel tank.
2 months 1 week ago #259250
by HUDCO
i dont know about co2 buut i use nitrogen for alot of thingslike finding leaks when you need 4 or 500 psi on somthing but to weld atank you just need 2or3psi and a 1/8 inch hole for nittrogen to escape preferablely on top
Fat Dan
Thank you received: 124
Thank you received: 321
2 months 1 week ago #259266
by Ray54
Would exhaust from a modern car with all the clean air devices still prevent combustion?
Years ago drove into the yard of a weld shop, engine driven welder running at high idle nobody around anywhere. Then I saw the hose on the exhaust of welder running to a tank. They are still in business, but with wine taking the whole area over they became the stainless-steel tank experts today.
Thank you received: 786
2 months 1 week ago #259289
diesel exhaust works so does dry ice which is essentially liquid carbon dioxide with the pressure taken off it. much easier to transport than liquid co2. the idea is you displacing the oxygen and fuel fumes.
the uncle has welded diesel tanks on trucks and earth moving gear fill it to normal full level with diesel before welding and have at it don't stop till the crack is welded and don't have the cap on.
Thank you received: 58
2 months 1 week ago #259303
by Mschwartz
Noticed ad on Facebook someone is parting out D2 and 22. Lewiston Idaho, dry climate, might be source for a better tank. Mike
Time to create page: 0.211 seconds
