D2 crawler to dozer conversion
2 months 2 weeks ago #259102
by Kendog_M
Thanks crs i will definitely keep that in mind, if need be I'm sure i can modify or fabricate a blade frame to fit
Thank you received: 8
2 months 2 weeks ago #259104
by d4e
I had a 5 roller D2 with 13” track pads . It had a 2 A dozer . that is wide as you could go without hitting the c frame on the dozer .
1 month 3 weeks ago #259542
by Kendog_M
Hi everyone i got a hold of an old d2 for myself and i think she's no bad, you will have to let me know what you all think. In future i will be posting for parts and advice so thanks in advance for all your help. The machine is a 1948 d2 5u with extended undercarriage.
Thank you received: 15
Thank you received: 772
1 month 3 weeks ago #259546
by juiceman
Congratulations! That unit with extended track frames is unique. Early serial number due to the pony (donkey) exhaust location?
Keep us posted. D2s are fun little machines. JM
Kendog_M
1 month 3 weeks ago #259549
by Kendog_M
Yep shes 5u1912 uf anyone has any histor in her id definitely be interested! Couple of things off the top of my head, thers slight lift in pony pulley, floor plates are missing beneath brake pedals, water temp guage doesnt appear to work and i think the steering clutches need adjusted. Is there workshop/ service manuals about for doing basic maintenance? I think the radiator only has water in it and not coolant, ideally id like to fix that before winter
Thank you received: 657
1 month 3 weeks ago #259550
If you can't get coolant into it, just drain it. The pony water jacket blows out very easily in a frost. Nice unit! We're going to need a video with walkaround and pulling. That scenery looks like NZ
1 month 3 weeks ago #259553
by Kendog_M
How do i post videos? I had a bit of trouble with it not wanting to load, also is cat coolant fine or would it require something else
