D 4 7 U rope start pony question
2 months 3 weeks ago #258943
by d4angelo
When I pull the rope to start my D4, the rope stops mid turn and almost separates my shoulder. This will happen 3 or 4 times in a row and then it won't happen on the next pull. What is causing this? The pony runs great, minor end play in the crank, no blue smoke when running and does not miss a beat. It can sit for 6 months, then start after only a few pulls of the rope. Any ideas?
Thank you received: 124
2 months 3 weeks ago #258946
by d4angelo
Thanks side-seat, I ALWAYS drain the heads before pulling the rope. Only a couple of drops of oil drain out, no fuel.
Thank you received: 657
2 months 3 weeks ago #258950
Does it feel like it's backfiring Angelo? Or does it feel like it just runs into a block and stops dead?
2 months 3 weeks ago #258956
by d4angelo
There is no backfire or miss at all. Purrs like a kitten when running. It just stops dead. After it stops dead, I can easily rotate the flywheel by hand. It does not feel like anything is binding at all.
Thank you received: 772
2 months 3 weeks ago #258972
by juiceman
You might have a bad gear or tooth on your pony or magneto. I have seen some with a bit of debris that clung to a tooth and would cause that on occasion.
You need to upgrade to the Italian Stallion starter, powered by hops, but I have heard "it" is worn out now. JM
Thank you received: 321
2 months 3 weeks ago #258976
by Ray54
I believe there have been threads on the mag shaft braking on D4's on here. If I am remembering correctly the thrust bearing is letting the shaft walk back and forth. At some point the gear locks against the case. Mag shaft is the weak link that brakes. This might not be your problem, but it could be. So check the play in the crankshaft.
