D7E Clutch Brake Replacement Question
3 months 3 days ago #258775 by Magneto
The adjustment on the clutch brake on my D7E 47A is all used up and I assume that the brake band needs to be replaced.  The transmission grinds about half the time when shifting. The forward reverse lever also keeps getting loose on the shaft which doesn't help any. I have the service manual for this tractor however it is unclear to me as to whether the universal joint assembly needs to come out for this. Can the band be slipped over the joint? Any idea on parts availability?
D7E 47A
3 months 2 days ago #258776 by gemdozer
NO You have to removed the bracket 9f7108 and removed the rod 6b4285 and you can removed the brake band 9f8979 and change the facing
3 months 2 days ago - 3 months 2 days ago #258777 by seiscat
Parts are still available.
Shoe assembly: 9F8992 about $69
---or the separate parts---
9F8976 facing  1
6B4284 rivet  4
9F8979 band 1
Craig
Last edit: 3 months 2 days ago by seiscat.
3 months 2 days ago #258778 by Magneto
Thanks guys, you saved me a lot of unnecessary work. I have the parts on order from the local cat dealer.
D7E 47A
2 months 3 weeks ago #258953 by DManring
Hey, yeah I thought I’d add in. I’m working on a 73T the shoe holes or walled out pin that a pivots on walled out so I ordered them from the local cat dealer to be here Friday.
Time to create page: 0.167 seconds
