D4 main clutch shaft bush
Thank you received: 23
1 month 2 weeks ago #258296
by Haus
I'm replacing the main clutch shaft bushing.
The bush (1F2830) and shaft are worn. Is there already a thread about this? I can't find anything.
Paul
Thank you received: 97
1 month 1 week ago #258312
by side-seat
I've made new shafts and bushings for a few of my D2's and D4's. Gotta orient the woodruff keyways correctly on some of them. Looks like it didn't wallow out the clutch cover casting. I had that before and had to bore the casting true before pressing in new oversize or custom bushing. Check the bushing in the bottom of the clutch compartment too. It may be worn but not as bad as the top one.
Soo Nice having a clutch mechanism that has no play!
Haus
Thank you received: 622
1 month 1 week ago #258313
110% agree with side-seat - the improvement in operability and adjustability with slop removed from the linkage is quite possibly the best outcome from the refurbishment of my 5U - the clutch operates with a clean, precise, and minimal operator movement and effort. The new brakes and steering just makes the whole tractor a joy to operate. By comparison, my buddy's HT4 is at the other end of the spectrum and it's hard work, inefficient to operate, and almost impossible to adjust to a stable, usable condition. We're definitely doing steering and brakes in that unit
Haus
1 month 1 week ago #258329
by Haus
Luckily the bush wasn't worn through. The clutch cover is ok.
I had a go at building up the shaft with the arc welder. It seems to have worked well.
Paul.
1 month 1 week ago #258347
by Haus
Here are some pictures:
Worn shaft
After welding
Turned back down
I warped the shaft very slightly. Not enough to be worth straightening though (I think). Not sure what else I could have done to keep it from warping other than get it hotter before starting to weld.
Paul.
1 month 1 week ago - 1 month 1 week ago #258368
by Haus
Does anybody know if this is an original grease point, or is it something added later?
The bush I removed did not have a hole to permit grease entry.
Paul.
Last edit: 1 month 1 week ago by
Haus.
Time to create page: 0.154 seconds
