Fuel pump bleed wrench
1 month 3 weeks ago #258093
by CodyKroeker
I’m working a a 2T D4 and after replacing the fuel filters I can’t seem to get the air out of the system to get it to run. Ive seen a special wrench to get the 1/4in bolt head on the back of the individual pumps and was wondering if anyone knows one for sale or any other special tools for a d4
Thank you received: 915
1 month 3 weeks ago - 1 month 3 weeks ago #258094
by Deas Plant.
Hi, CodyKroeker.
If you ask your friendly local Cat dealer spare parts man VERY nicely to look in the Classic Cats section of their digital parts listings for such a tool, it may just turn up.
LOTSA things hiding in there that don't show up in the normal listings.
A search on e-bay for "Caterpillar Fuel Injector Pump Bleed Tool' may bring up that jigger too.
Last edit: 1 month 3 weeks ago by
Deas Plant.. Reason: spel-ink.
1 month 3 weeks ago #258095
by CodyKroeker
I looked already I didn’t see any. I know I’ve seen a cat part number somewhere I just can’t remember where I saw it
Thank you received: 172
1 month 3 weeks ago - 1 month 3 weeks ago #258097
by josh
The modern tool for that is a 1/4" drive oval socket, part number 5P2682, the old style wrench is a 9F22, or 9F0022.
josh.
Thank you received: 139
Thank you received: 50
Thank you received: 6
1 month 3 weeks ago #258101
by rhartwick
It had never occurred to me over the years that the oval bleeder screws were the same oval profile and size at the top of a common shock absorber. I looked up the A137 part mentioned by cr, and they are available everywhere as shock absorber sockets. I wish I had known that years ago. In a pinch, I used the heavy wire bail off an old milk bucket, and squeezed the round end into an oval in a vise then bent the wire similar to the Cat tool. The bleeders don't take much to turn, and that worked fine for me for many years. Now, I think I'll buy on of those A137 sockets in 1/4" with a universal. Should be a lot handier.
Thank you received: 722
1 month 3 weeks ago #258102
by juiceman
Another huge thanks to CR; I have been on the "Snap-Off" wagon a time or two, and my ex salesperson could never seem to help. If one has the part # it makes life easier! I will order some for the tool boxes. Thx! JM
Thank you received: 33
1 month 3 weeks ago #258111
by bluox
The A137 is 3/8 drive that is why the Cat socket is 1/4 drive.
Why on earth don't you just use a 3/4 or 19mm open end wrench and loosen the fuel line nuts to bleed air?
Bob
1 month 3 weeks ago #258116
by CodyKroeker
I tried to and I wasn’t getting any fuel movement from the pump to where the line goes in or at the injector itself so I wanted to try there to see if I could get fuel somewhere
Time to create page: 0.199 seconds
