D47u pony starter motor install
2 months 2 weeks ago #257622
by glebis
I removed the electric start from the pony motor, but unable to seat it fully when re installing it. Any hints?
Thank you received: 25
2 months 2 weeks ago #257627
by cheshire cat
Where the nose of the motor goes into the hosing? Think you just clean any rust and dirt off apply a little grease note where the hole in the starter is remove the pointed bolt and slide it in until the holes line up then tighten the bolt enough to hold it in place and then the lock nut up ..hope that helps..
glebis
Thank you received: 622
2 months 2 weeks ago #257630
Are you talking the entire mount including top cover, or just the motor into the round bracket with the stop bolt like Cheshire mentioned, or the pulley and gear assembly?
glebis
Thank you received: 313
2 months 2 weeks ago #257633
by Ray54
If it is starter into the round bracket, get it shinny. Wire wheel or emery paper to get the rust off. And some lube as cheshire cat says. I have put anti seize on it, rather than oil.
glebis
2 months 2 weeks ago #257640
by glebis
Thanks for the replies, I removed the entire starter by first removing the single retaining bolt. I haven’t been able to get back to it but I have a theory, before removing the pointy bolt I removed the two bolts holding a backing plate that sits between the pony gear and starter, then reinstalled the bolts when I realized that’s not how you remove the starter, I think I introduced an alignment problem. I will post an update in a few days.
2 months 2 weeks ago #257642
Sounds about right, if that gear is displaced
glebis
Thank you received: 722
2 months 2 weeks ago #257649
by juiceman
Use some caution when trying to put it back in place. As everyone else said, shine things up very good, and use something like Never-Sieze in case you need to pull it out in the future.
I had a bugger of a time removing one last week, short of using heat. Pinch bars, loose juice and a 4# sledge-O-Matic and patience. No swear words. Good luck. JM
glebis
2 months 2 weeks ago #257659
by glebis
Thanks again everyone for replies and encouragement. I was able to get out there again today, got everything aligned and the starter installed, the pony fired and diesel running, it’s a 53, still going strong (unlike me who is also ‘53 but wearing out fast
Time to create page: 0.160 seconds
