D318 motor non running;things to check before starting
9 months 1 week ago #254772 by Michael Crowe
I bought a no 12 grader that the previous owner bought for parts from a friend and it is supposed to have a good pony and diesel engine. Besides checking the fluids, stuck fuel rack, is there anything particular to the D318 engine i should check?
ive had a couple D2’s and D4’s but none with the D318 engine.
if everything looks ok ill try to start with the pony motor; if not i may try to pull start it.
Thanks Michael
9 months 1 week ago - 9 months 1 week ago #254776 by rax200
Hi Micheal,
If your D4 is a 6u or 7u they have a D315 engine, the D318 is only two more cylinders
So the same would apply to the d4.
You can also make shore that the engine turns over buy hand buy operating the decompression lever and give it a few turns over and feel for any abnormal signs.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Last edit: 9 months 1 week ago by rax200. Reason: Added txt
The following user(s) said Thank You: Michael Crowe
9 months 1 week ago #254779 by trainzkid88
use a borescope to check the manifolds for obstructions or damage. especially if the exhuasts havent been covered.
see if it turns freely
9 months 1 week ago #254788 by Michael Crowe
Thanks for the responses. As soon as we get a warmer day, ill get the picked up and will post some pictures.
9 months 6 days ago #254794 by side-seat
After all of the above. Then, If you can get the pony running, Turn the diesel over without compression and see if you get oil pressure.
9 months 6 days ago #254803 by rax200
For the pilot motor,i would change the oil as it only uses 1 litre because the old oil will be contaminated. This is cheap insurance and you know the oil is good.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
Time to create page: 0.153 seconds
