Cat r2 main clutch
9 months 1 week ago #254757 by Blue
Cat r2 main clutch was created by Blue
Hi, I have a lot of free play on the main clutch leaver on my cat R2 6J617SP when i push the leaver forward to disengage it hits the tank but when you pull it back it has a nice snap to it. Just wondering what the adjustment should be?
thanks
9 months 1 week ago #254765 by Peter C
Replied by Peter C on topic Cat r2 main clutch
Blue, these pictures might help a little. They are from my 6J with the clutch forward as far as it will go and with the clutch pulled to the rear in the engaged position. Disengaged lever is about 4 inches from fuel tank. Engaged lever is about 13 inches from the tank.
Pete
9 months 1 week ago #254767 by Blue
Replied by Blue on topic Cat r2 main clutch
Thank you, I now have something to work from. I will have a go at it tomorrow and see if I can get it to these numbers, I will let you know the progress.
9 months 1 week ago #254768 by Deas Plant.
Replied by Deas Plant. on topic Cat r2 main clutch
Hi, Blue.
I'm no 'ex-spurt' on R2s but, if it is supposed to have a clutch brake and that is not working/outa adjustment/missing, that could explain your extra lever travel.
9 months 6 days ago #254807 by Steve A
Replied by Steve A on topic Cat r2 main clutch
There is a bushing on the top of the housing where the vertical clutch shaft rides, when that gets worn you will get excessive play.
9 months 6 days ago #254818 by neil
Replied by neil on topic Cat r2 main clutch
If you tighten up all the slop, you'll find the movement much reduced, and the clutch feeling much snappier and easy to adjust. I did that on my D2 and it feels like what I imagine a brand new tractor felt like
Time to create page: 0.160 seconds
