Question about Hyster towing winch for Cat 22?
Thank you received: 54
9 months 3 weeks ago - 9 months 3 weeks ago #254459
by Peter C
Hi, I'm trying to take a Hyster towing winch apart to get it into operating condition and have a few of questions. I'm now trying to remove the cable drum from the metal casing.
1. Does the chain drive have a master link that I can remove? If not, then I'm guessing that I have to remove about 6-8 bolts that are sort of visible with the red arrows and accessed through the hole in the casing circled in red.
2. Does anyone have the parts and the operator's manuals and would be willing to sell or scan a page or two showing how the sprocket is attached to the cable drum??
Pete
Last edit: 9 months 3 weeks ago by
Peter C.
Thank you received: 659
9 months 3 weeks ago #254475
I don't Peter, but boy am I interested in seeing LOTS of detailed pictures as you disassemble it.
Thank you received: 186
9 months 3 weeks ago - 9 months 3 weeks ago #254480
by josh
The picture you have posted about the features of the winch are much better than the parts and installation manual. There is no master link in the parts list, just chain, you will have to go over the chain and see, also it looks like you can see the cap screws that hold the sprocket onto the drum in your picture, but not in the parts book.
josh.
Thank you received: 502
Thank you received: 26
9 months 3 weeks ago #254485
by daron
Roller chain without master link?
I do not ever recall working on a roller chain without master link.
CTS
How about automotive timing chains?
Daron
(I did get the set from Rob Mcleary. Nice.)
9 months 3 weeks ago #254487
by ctsnowfighter
Yes Daron,
Timing Chains, Chain Saw Chains, Bicycle Chains, to name a few that did not have master links per say.
There is always an exception.
CTS
Thank you received: 84
9 months 3 weeks ago #254490
by mog5858
very neat. but how are you going about reversing the drum? or is it just power in and the dog it out for free spool? simple but sometimes them dog to like to shift especially under load.
thanks for sharing.
9 months 2 weeks ago - 9 months 2 weeks ago #254523
by Peter C
Thanks every one for all of the input.
Josh and every one, I did find a master link on the chain AFTER I got it all apart and cleaned up. Here are some pictures.
mog5858: Yes, there is no reversing of the drum. It is free wheel out but the brake is missing so it will only be to lengthen the cable. Here is the sliding clutch for free spooling:
Neil, here are pictures. I use them for reassembly hoping every thing was correct when I disassembled it:
Last edit: 9 months 2 weeks ago by
Peter C.
Thank you received: 787
9 months 2 weeks ago #254569
that is normal duplex drive chain it will have a joiner link they can be "fun" as there is a fish plate in the middle too.
yes while many timing chains dont have a joining link some do. ive worked on stuff that did. saw chains and bicycle chains use a chain breaker press and a rivet spinner to break and make the chain.
9 months 2 weeks ago #254593
by mog5858
thanks for the info. that really is a very simple but effective way to to make a dog clutch I like it.
Time to create page: 0.212 seconds
