No 12 Grader Flywheel
9 months 3 weeks ago #254337 by Walker
No 12 Grader Flywheel was created by Walker
Hello Good People!  I have what I believe to be a 1956 No.12 Grader (80C475) with a D318 and a wet clutch and electric start. A year or two ago part of the flywheel gear decided to give up the ghost. I pulled the starter and saw the damaged flywheel teeth preventing the starter from engaging and I have been having to pull it to start it since then.  The machine runs great otherwise so I would like to replace the flywheel assembly and/or the gear. I am not pulling it apart until I can find a replacement part to fix it so I don't know exactly what I will be looking at once I get in there, but I know for certain the gear teeth are damaged.  Which leads me to my question, does anyone know where a guy might be able to source a flywheel?   After digging the through the parts manuals in the library, which is an awesome resource by the way, I THINK the part i am looking for is either 5H42 flywheel assembly or a 786253 gear. I am just not having any luck finding one online.  Any possible leads would be much appreciated.
Walker
9 months 3 weeks ago - 9 months 3 weeks ago #254338 by rax200
Replied by rax200 on topic No 12 Grader Flywheel
If you lookon the website Machinery Trader and punch in the number 5H0042 there is some there.
If you see a part number 5h42 yo must make it to a min if 6 digits foe example,
5h42 - 5h0042
S1594 - 0S1594
S509 - 0S0509
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Last edit: 9 months 3 weeks ago by rax200. Reason: Spelling
9 months 3 weeks ago #254339 by Old Magnet
Replied by Old Magnet on topic No 12 Grader Flywheel
Look for 5H0042 flywheel and 7B6253 Gear
9 months 3 weeks ago #254340 by Walker
Replied by Walker on topic No 12 Grader Flywheel
Thank y'all very much!
9 months 3 weeks ago #254342 by ctsnowfighter
Replied by ctsnowfighter on topic No 12 Grader Flywheel
Would you need to replace the flywheel or is the ring gear replaceable, heated to install and driven off to remove?
Might it be a good idea to ensure the pinion on the starter is also in good shape so you do not damage the replaced flywheel/ring gear assembly.
cts
9 months 3 weeks ago #254345 by Dandy Dave
Replied by Dandy Dave on topic No 12 Grader Flywheel
Your Grader is a 1957 Model year. D-318 with 115 HP Direct Electric Start from the factory. Produced from 1955-1967.Weighs approx. 22,000 LBS.
1940 Cat 12 Grader 6M17
1956 Cat D2-5U
1956 Cat D6- 9U 23721
Copake, NY.
Time to create page: 0.146 seconds
