- Thank you received: 772
Righty and not a lefty eh? My own experiences with every D6 as well at the D5s; adjust brakes and steering to proper specifications; Open the access port at the right rear of machine; I have seen many that had contamination from weeping seals, allowing the brake band and drum to get soppy with oil. Take a large can of brake cleaner if so, and spray generously to clean the crud off. If you are lucky, that might be all you need to get many hours of use before a proper repair of the leaks, etc. Good luck. JM
***seems like the right side always leaks first***
***So I was correct???***
support@acmoc.org
- Chris R
- Jason N
