Late D4 brake pawl pin
10 months 2 weeks ago #253843 by Haus
Late D4 brake pawl pin was created by Haus
I have to replace the brake pawl pin (3B1137). I can't see it listed on cat parts so assume it's discontinued. It looks like it's 3/8" X ~3" long. Part catalog looks like it may have had a cotter pin in one end(?).
Assume I'll make a new one. Any advice on what kind of steel it should be made of? I need the brake lock to work as it's very steep where I am.
​​​​​​Paul.
10 months 2 weeks ago #253844 by Haus
Replied by Haus on topic Late D4 brake pawl pin
Late 6U I meant. Whoops.
Paul.
10 months 2 weeks ago #253870 by juiceman
Replied by juiceman on topic Late D4 brake pawl pin
I would suspect getting some cold rolled would be your best bet, but see no reason why you couldn't get by with hot roll.
Where are you located?
That broken pin will be a fun job to remove. JM
10 months 1 week ago #253878 by Ray54
Replied by Ray54 on topic Late D4 brake pawl pin
You need to get the old part number into the computer age with the right number of 0 in the right place, which I always forget. Partly because my dealer still has some old time parts persons. Really needs to be pinned and in a prominent place on this board.
The following user(s) said Thank You: gauntjoh, Haus
10 months 1 week ago #253887 by trainzkid88
Replied by trainzkid88 on topic Late D4 brake pawl pin
try as ray suggests for the part number. for example 5b624 would become 5b0624. the cat parts system is set up for 6 character part numbers
if you can't get one a grade 5 high tensile bolt will work just fine and coat the thing with a little copper or nickel anti seize it will lube it and prevent fretting corrosion.
any decent engineering supplies should also be able to supply a cotter pin the right size.
The following user(s) said Thank You: Haus
10 months 1 week ago #253888 by trainzkid88
something to remember one of the best brakes in the world is an implement and a stout tree.
Time to create page: 0.152 seconds
