Twenty eight project
Thank you received: 76
10 months 3 weeks ago #253666
by deereskinner
Skinner, I think I bought the manifolds off your twenty eight, so I have your good intake and drop tube, I can use my exhaust, I just need to fabricate a heat box or fill the gap somehow and I should be fixed up, can't think of anything else on your parts cats that I need at the moment, but glad to have the resource, thanks
Thank you received: 167
10 months 3 weeks ago #253669
by Skinner
Ok good deal. I wasn’t sure if they went to you! Or someone else up your way. Lol I haven’t seen Chris since he was here loading them up. Good luck with your project. Skinner
10 months 3 weeks ago #253670
by deereskinner
Thanks John, I luckily have a neighbor who has a twenty eight he resurrected about twenty years ago for an example for me to follow, he actually built his own drop tube and made a heat box without a dampner because his were beyond repair. That worked out so perfect to have Chris bring me the parts, I was actually looking for grain drills for him when I found this 28. LOL
Thank you received: 115
10 months 3 weeks ago #253680
by naylorbros
This heat valve might be available in a couple of months.
I replaced it with one that I got from Jon. The valve is loose, all new studs and nuts, the bad is it has had two cracks repaired at some point in its life. I also sent a pm to you.
Ken
Thank you received: 34
Thank you received: 106
10 months 2 weeks ago #253729
by Skinner
Greengiant
theres only one with a crank and it’s been welded several times, and in rough shape
10 months 2 weeks ago #253730
by greengiant
thanks for checking. I can get by with one that i had modified from a crank left over from a D7M that i sold for scrap, it's not pretty but is functional. my original 28 crank just vanished mysteriously.
Time to create page: 0.169 seconds
