Bill Glenns Classic Plant Monthly
17 years 7 months ago #2236
by tctractors
Here is a few shots of an early D8 tractor that I am pulling to pieces with David "the tractor" Moggerage, David is now 69 years of age and still works harder than most. This D8 is in the S.E. Davis collection (the people with the TC 12), on Tuesday I am going to remove the engine, clutch, and strip the gear box. The pictures of the Daewoo excavator show me lifting in a trackdrive gear box under its own steam. The big red shiny thing lay on the floor with a heap of bits is what i bought myself for Christmas, its a 105 tonne ram with 3 new legs the picture of the dump trucks are just some I was called out to repair, I was told to turn up to repair a dump truck, I asked which one, they said "please yourself theres nine out there and they are all MULLER'D!!!..." so I have been busy.
The pics of the glorious Atlas are just a foretaste of lots more to come, this tractor was converted by Henry Kaiser and is believed to be the first one converted in this fashion, and was kept for years in the Pleasanton aggregate plant of Kaiser Paving. As the pictures show the tractor has been restored to immaculate condition and is a true marvel to see working ( we are hoping to fit a scraper box to this tractor for the coming muck shifting season ) I will post a series of pictures following the restoration to show the full depths of the work entailed to get a tractor to this level. Sadly I didnt get to lay a single spanner on it, as they were scared I would convert it into a D7.
tctractors
p.s. America may have a knackered soccer player from England, but England have got the Atlas CAT 60.....what a deal!!!
Thank you received: 5
Thank you received: 72
17 years 7 months ago #2239
by bernie
Thanks for the pics-they show some nice details of pulling the sprockets.
Why did you switch the rams? Did the older one give out on you, or maybe not enough umph?
KoO-I was wondering the same thing. They look sike some sort of rail car but the tounge does not look like any coupling I have seen on one...
bernie
17 years 7 months ago #2240
by tctractors
Hi there King, the green waggons are for traction engine/roller drivers to live in whilst working away from home, these were towed behind the steam engine often hooked to other waggons/water carts etc as was needed within there scope of work, at the S.E.Davis Vintage yard there is stacks of machinery , steam engines,/lorrys crawler Cranes ,Motor scrapers, and possibly 200/300 tracked type tractors all shapes and breeds,I will put up some pic's soon.
tctractors
17 years 7 months ago #2241
by bernie
The wheels look like rail wheels...any significance?
Closer look. Maybe the one on the left is showing the rims and the one on the right has rubber tires on it. Hard to see at first.
17 years 7 months ago #2243
by tctractors
Bernie, the ram used to bang off the outer bearing hub is a heavy duty Cat 70 ton job , it is the correct ram to pull all sprockets from a D6C down to a D2, it weighs about a 100lbs, so its not to heavy to lift about a few times , the red ram weighs about 160lbs so it makes you snort a bit when you get ahold of the thing, David asked me why I had gone red in the face after lifting the red job a few times,I told him I must have breathed in a " Bad Batch of Air ", so I use the light ram if I can , that L/Hand sprocket was pumped up to 90 ton on the pressure gauge then I gave it a shot with a 28lbs sledge hammer to make it do as it was told (come off the taper).
tctractors.
17 years 7 months ago #2245
by tctractors
Bernie, the steel tyres are just an early style of wheel (the Horse and Cart period) the "Dunlop" inflated rubber job is from the "Motor Car period", I will take some pic's of the cabins for you.
tctractors.
17 years 7 months ago #2328
by tctractors
Today at the S.E.Davis Vintage collection ,the Editor with the top Commander of " Classic Plant " turned up to take in the atmosphere, this was Gary Boyd Hope and Peter Love, when I was introduced to Gary & Co, the Tctractor handle was soon falling off Gary's lips. I was working on one of S.E.D.'s many D8's , whipping out the engine & clutch , I felt very pleased that I gave such a good report on the last issue of the mag, (Irish approved By Neal D), as this seemed to smooth over a few sharp edges, they had a good tour around the 360 pieces of kit on the site which is very well set out with plenty of space to bang around on ,sadly I am stripping the D8 down in the pouring rain outside , but I think now I like it like that, at least I can see the sky. " It could be Darkness"
Happy to be wet, tctractors
17 years 7 months ago #2350
by MARTYN WILLIAMS
Hope you gave Peter and GBH a warm welcome, were they looking for a JCB to photograph? or 1/2 a tractor!!
Any pictures at SE Davis to go on this bb.?
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
17 years 7 months ago #2360
by tctractors
Martyn , I was on my best behaviour the whole time , I have taken some great pics of the main site that is set aside for the old "Junk" also some good pic's of the engine drivers Waggons , one is fitted with the bogey wheels off a "Tank" from the early part of WW2, but I am not sure I can post them ,as my Red band is nearly filled up the green band on the posting quota, is it renewd monthly ??? or am I done for.
nearly off the clock , tctractors,
PS, D4C24a if you need a sub to cover your membership , you only have to ask, your credits good????????,
