60 Scraper Apron Cable Replacement
11 months 1 week ago #253017
by D8PETE
I need to replace the apron lift cable on my 60 scraper. Its a 9/16" diameter, 6x19 lang lay steel cable. I asked my local supplier, Hanes Supply, if they had a 9/16" lang lay steel cable and they do not. I only need about 20 feet of cable so I do not want to special order a whole roll. All the rest of the Cat machines use 1/2" cable so I have no other needs for extra 9/16 cable. Does anyone know where I can buy the correct cable? Anyone have recommendations for a substitute if I can't find the exact 9/16" cable? They have a 9/16", 6x25 regular lay in stock.
Thank you received: 928
11 months 1 week ago #253018
by Deas Plant.
Hi, D8PETE.
I think you will find that ALL Cat scrapers and dozers ONLY used 1/2" cable all around - except for the apron lift ropes on their scrapers. The reason they used heavier ropes for the apron lift is that it was only a single cable attached to a sheave block that was part of the apron/ejector system.
Look for someone who has a dragline or a cable crane which uses 9/16 rope and ask if they can cut you off what you need. A crane hire company that uses cranes with cables might be a good place to start.
Thank you received: 788
11 months 1 week ago #253025
yes crane rigging companies regularly change cables so they possibly have some that you could acquire at the right price. never know they might have then end of a roll or be willing to sell the length you need
Time to create page: 0.127 seconds
