Pony carb float bowl screws.
11 months 3 weeks ago #252892 by Dozerman51
What thread size are the pony motor float bowl screws on a D2/3J carb. Thanks for any help.
11 months 3 weeks ago #252895 by Old Magnet
If your referring to the float bowl lid screws they are #10-32 tpi. Two at 1/2"length and two at 3/4" length. Run a tap to clean the threads.
11 months 3 weeks ago #252896 by Dozerman51
Hello Pete. Thanks for the info. Hope you are doing well. 👍👍👍
11 months 3 weeks ago - 11 months 3 weeks ago #252902 by trainzkid88
a light smear of grease on the tap will trap any shavings or crud. its a old trick and it work well in blind holes. and it lubes the tap you can also use rocol paste etc too
Last edit: 11 months 3 weeks ago by trainzkid88.
11 months 3 weeks ago #252922 by Dozerman51
Thanks for the lube tip. 👍👍
11 months 2 weeks ago #252928 by PhilC
Replied by PhilC on topic Pony carb float bowl screws.
Don't use grease. Use a proper cutting compound. Grease is designed to stop things cutting a tap is designed to cut.I know a lot of people will use grease but it can actually be detrimental to the cutting edge of the tap.
If you have an air compressor just blow the hole out with air. (safety glasses of course)
Time to create page: 0.154 seconds
