sprocket pulling tools
Thank you received: 84
11 months 4 weeks ago #252802
by mog5858
looks like I will be needing to build some final drive tools to pull a sprocket off a D6 8u-9U. can some tell me if I got the size of the foot about right? pins look to be 3/4" inch puller legs are 19" long. plan is to make them from 4330-V thanks
11 months 3 weeks ago #252912
by Mike Hudson
Mr Mog that looks just right. To get started. A little trial and error and you will have those sprockets on the ground. There is just something difficult about starting something especially if we haven’t did it before. Lot of luck. Mike Hudson
11 months 2 weeks ago #252955
by mog5858
thanks for your help. yes I know all to well about doing things that we haven't done before just cus someone else had problems doing it doesn't mean you'll have the same results but it always there in the back of your mind for sure.
Thank you received: 124
Thank you received: 502
11 months 2 weeks ago #252973
by ctsnowfighter
Reminder -
The tonage is high when pulling sprockets, remember to leave the nut in place, stay on the opposite side of the tractor if possible so you have as much iron between you and the sprocket as possible. Any mishap sends shards of steel flying like fragments from a bomb!
Pulling the sprocket is only half the issue, it has to be pressed back on too, requiring more tooling.
CTS
Thank you received: 816
11 months 2 weeks ago #252975
I believe you are pulling sprockets from wide gage D6?
The T-section of your item shown might be to thick if pulling narrow gage when your up against the final drive case.
11 months 2 weeks ago #252981
by Mike Hudson
Well, if that be the circumstances then he will find that out as soon as he begins. Circular dimensions are difficult for the average without drawing skills and 3 d equipment. So it to early to can the project
11 months 2 weeks ago #252993
by mog5858
yes I will most like be pulling wide or 9U as that's all that around hear for parts machines. the project cat is a 8U but that's the only one I ever seen up in Canada
Time to create page: 0.158 seconds
