Zenith TU-4C info needed
1 year 6 days ago #252654 by Dozerman51
Working on a TU-4C pony carb body. Have removed the throttle plate and shaft. How do you remove the choke plate from the shaft. This shaft has a slit in it where the plate is set. I have removed the 2 screws from the plate and shaft, but I can’t seem to remove the plate by lifting it out of the top of the carb body. Does it have to be removed from the bottom? Thanks for any advice.
1 year 5 days ago #252661 by Deebo
Replied by Deebo on topic Zenith TU-4C info needed
There’s a TU-4C service bulletin in the members Technical Library. Worth joining for the wealth of info!  Here’s a screenshot to help you out;
Regards,
Tony
The following user(s) said Thank You: seiscat
1 year 5 days ago #252666 by Dozerman51
Replied by Dozerman51 on topic Zenith TU-4C info needed
Thank you Deebo.👍👍
Time to create page: 0.125 seconds
