26x d5 sa injecton pump
1 year 1 week ago #252579 by HUDCO
the rack will stick shut and will not restart when cold , if it is killed with the clutch and the throttle is left on it will start what needs to be done now to fix it  will several fuel filters full of atf work ?
1 year 1 week ago #252580 by Old Magnet
Replied by Old Magnet on topic 26x d5 sa injecton pump
What's the serial number and is it Scroll or Sleeve Metering Injection pump?
1 year 1 week ago #252590 by HUDCO
Replied by HUDCO on topic 26x d5 sa injecton pump
d5b z 26x01147 dont know what the z means and i do not know if it is a slaeve metering or schroll
1 year 1 week ago - 1 year 1 week ago #252591 by Old Magnet
The D5B went to Sleeve Metering at s/n 26X0878. Those injection pumps are prone to rusting if any water gets into the fuel, especially when units set for long periods of time. The sleeves will stick on the metering shafts. There is no magic fix other than tearing into the pump and cleaning any rust or deposits that are restricting the sleeve movement.
Last edit: 1 year 1 week ago by Old Magnet.
1 year 1 week ago #252595 by HUDCO
what needs to be done to pull the pump ? and is there a specific service publication for this pump or engine. thanks hud
1 year 1 week ago #252605 by Old Magnet
You need to get the Cat Service Manual for the D5B 26X or for the non SA D5B's with 3306 engine.
Usually can be found on ebay.
1 year 1 week ago - 1 year 1 week ago #252619 by Jake
Replied by Jake on topic 26x d5 sa injecton pump
Here is the service manual for the sleeve metering system.
Edit:  Sorry cant load file.
Last edit: 1 year 1 week ago by Jake.
1 year 1 week ago #252621 by HUDCO
their are alot of manuals on e bay right now but all skip 26x
1 year 1 week ago #252627 by Old Magnet
As far as disassembly and assembly of the injection pump, any 3306 engine with the sleeve metering pump uses the same information,
1 year 1 week ago #252633 by Jake
The service manual is in the library now.
