Technical Library
1 year 3 weeks ago #252253 by Mike Hudson
Replied by Mike Hudson on topic Technical Library
Can do man, good morning.  I been on here paying about a month so I still have a lot to learn. The library I can access but it’s no where near having a manual.  Utube offers a lot of help on just about anything you could work on. The folks on other forums are more helpful also, I like Tractor by net. Good luck sir
1 year 3 weeks ago #252258 by Elton
Replied by Elton on topic Technical Library
Good afternoon! I too have questions. John helped me get into the system, thanks John! My D4 7U36219 has a #44 hydraulic system. I am having major leaks out of the drive end. I looked up in the Library system which parts catalog to use for my system which is 9W7594. The Library search led me to catalog ue032888 but it does not (that I can find) have a listing for 9W7594. Am I missing something? If it is indeed not there, I would appreciate a copy of the exploded view of the pump mechanisms and the drive. Also does anyone know what Speedi-Sleeve fits the drive shaft? Thanks all! Elton
1 year 3 weeks ago #252261 by bruce oz
Replied by bruce oz on topic Technical Library
44_HYDRS_6W_7W_8W_9W
The following user(s) said Thank You: Busso20
1 year 3 weeks ago #252263 by Rome K/G
Replied by Rome K/G on topic Technical Library
If you overfill the tank it will blow that seal out too.
1 year 3 weeks ago #252279 by Elton
Rome, thanks for your help! How do you know the correct level? The blade has been pretty slow to react, should I take the pump to the hydraulic shop or deal with slow? Thanks again! Elton
1 year 3 weeks ago #252280 by Rome K/G
The operation and maintenance manual reads "level should be visible in filler neck".
1 year 3 weeks ago #252281 by Elton
Thank you!
1 year 3 weeks ago - 1 year 3 weeks ago #252282 by josh
Replied by josh on topic Technical Library
If the input shaft is leaking, the parts you will need, are the 5F4721 seal and you may need the collar, 5F4722 collar, which is a sleeve. You do need to pull the #44 unit to access these parts and while you are there, you can pull the pump cartridge to inspect it and the bearings, it will be pretty easy to see if it's worn enough to cause slow performance,
The serviceman's reference book for Hydraulic controls in the library will be very helpful. The new type seals will be different than the old, and you may find that since they are thinner you can position it so that the sealing lip sits on a non worn spot on the collar. Care should be taken when disassembling the pump cartridge so you don't drop the vanes out of the cartridge and mess up their orientation.
If you find that it is just the end plates in the pump that are worn, they can often be resurfaced or built up and the cartridge reshimmed as described in the service book.
Last edit: 1 year 3 weeks ago by josh.
1 year 3 weeks ago #252284 by bcwayne
Replied by bcwayne on topic Technical Library
I had a #44 pump on a D2 whose blade moved slower than it should. Changing the sock filter cured the problem.
1 year 3 weeks ago #252295 by trainzkid88
Replied by trainzkid88 on topic Technical Library
and the filters are still available from cat. i got one for ours still havent put it in though. getting it running again has been the priority.
Time to create page: 0.197 seconds
