Value Group 7F4307 44 control unit
1 year 1 month ago #251820 by cfbromm
Could use some advice on stem and base unit. Disassembly the unit and found rust and some deterioration on the stem and not sure of the base.Can this be repair or replaced. Any advice on this matter. Thanks for any advice.
1 year 1 month ago #251821 by juiceman
I will be following this thread. Many of us have 44s as well as 41s, I would guess that has affected the operation of your pump?
It would be interesting to know if a hydraulic shop can "Parkerize" it, and lap it smooth, or have a machine shop (crank or camshaft experts?) rebuild it to specs?
You would not be the only one with this situation, being these units are so old.
One wonders if a new one is floating about in the inventory of a dealer somewhere.
Keep us posted on any progress please. JM
The following user(s) said Thank You: cfbromm
1 year 1 month ago #251823 by josh
That looks pretty bad, I would bet the valve body is bad as well. It is my understanding that the spool and body are a fitted pair and as such, it may be difficult to repair. Your best bet might be to find a good used valve assembly, they were used on lots of tractors and most dismantlers seem to have something around, one of those things, that if you work on them very often, you pick up units or parts when you can.
The following user(s) said Thank You: juiceman, cfbromm
1 year 1 month ago #251824 by cfbromm
Thanks for the advice.
Maybe there is one available.
1 year 1 month ago #251844 by trainzkid88
maybe devcon epoxy or silicon bronze to build up the worn areas line bore the the body to a size and then machine the spool to that size.
thats how they were made the body was rough made undersize and the shaft was oversize and then machined to fit each other
silicon bronze would be my preference.
any decent machine shop should be able to do this.
1 year 1 month ago #251846 by cfbromm
Thank you for the offer of the hydraulic 44 unit. I'll keep that in mind. It is the distance from me.
1 year 1 month ago #251851 by josh
That is not my hydraulic unit, just posted it to show they come up. Where are you located? I may have a valve assembly but it will be a few days before I have time to look.
1 year 1 month ago #251865 by cfbromm
Josh
Thanks, for the response.
Yes, if would find value, let me know.
I'm in northern Minnesota.
Thanks again
Corky
1 year 1 month ago #251866 by josh
What is the condition of the cartridge (pump) and input shaft, just wondering since the spool is so pitted.
